Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric Helicopters > Micro Sized Electric Helicopters > E-Flite Helicopters
Old 01-09-2010, 07:26 PM   #26
vortex05
Blade CP, Blade 400
neat, unexpected but neat.
vortex05 is offline
Old 01-09-2010, 08:19 PM   #27
iflyrc1012
Insane Wiggy pilot
iflyrc1012's Avatar
Globetrotter Pilot
Friends: (19)
Vortex,
I just need you to teach me EVERYTHING i need to know a.s.a.p!!! LOL!!!
Thanks for the info.
iflyrc1012 is offline
Old 12-25-2017, 07:20 PM   #28
Frayedknot420
Default No power to tail motor through board
Do you have any ideas of what could be the problem if I can't get power to my tail through the board? I'm stumped and don't have the loot for a new 4 in 1 or brushless conversion. Help is appreciated
Frayedknot420 is offline
Old 12-25-2017, 10:19 PM   #29
vortex05
Blade CP, Blade 400
As far as I know there are 2 ways to get your tail working if you look at the first picture in this thread there are 3 rectangular IC chips the 2 in a row are for the main motor the single 1 on it's own is for the tail if I remember correctly.
You should be able to get it working again just by replacing the original IC's if it's the tail it will be the one on its own.
Now as for the other way I've done some conversions in the past and the signal for the tail actually runs through one of the two 6 pin connectors on the back you can think of them as standard 2x3 pin jst connectors the signals are the same order as you normal plug in the wire that is it should be: ground +5v signal.
So another way you can bypass the built in motor driver is you can wire an external ESC to the reciever's pins and have the signal sent that way to drive the tail. In this case however I would think the 4 in 1 repair is ultimately cheaper it's just difficult to locate the original chip.
In terms of what I eventually did to my Blade CP before I sold it I wired a spektrum AR6100e to it sent two inputs into those same 6 pins to drive the motors and get the gyro signal.
The blade CP platform was quite capable you can treat the ESC unit on the blade CP as just an ESC and feed the signal from an 2.4Ghz reciever it actually helps the glitching a lot if you don't have money for a spektrum I would recommend looking at the OrangeRX series that tend to be dirt cheap clones.
the Blade CP 4 in 1 ultimately is a bit overpriced if you want to replace it for the same price you can get a knock off OrangeRX reciever $15 a better gyro $15 Hobby king and then you just need a bit of money left over for some ESC's to drive the motors. (unsure but they range from $12 to $30).
It really comes down to are you ready to upgrade your Radio since the thing you hold in your hand will be the thing that sets you back the most.
vortex05 is offline
Tags
3in1 , 4in1 , alright , blown
How accurate can you build a plane from a blown up 3view? GreenAce92 Foamies 9 12-21-2007 02:39 PM
4 in 1 blown by reversing a servo? vortex05 Micro Sized Electric Helicopters 17 06-27-2007 01:37 AM
alright where is everyone dmmalish General Electric Discussions 6 05-06-2007 01:29 AM
Alright I went and upgraded a bit Jettlagg Micro Sized Electric Helicopters 2 02-22-2007 01:35 AM
Blown Lama 4-in-1 Tachikoma Micro Sized Electric Helicopters 5 06-11-2006 03:37 AM
Page generated in 0.10880 seconds with 29 queries
