Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Scale E-Powered Aircraft
Old 02-16-2018, 06:59 PM   #1
F22trainer
Default Eflite PT-17
I could not help it...
https://www.motionrc.com/collections...lite-pt-17-bnf
They marked them down and I was always hypnotized by one club members model, that I just had to have one.
With AS3X it's a real jewel.
F22trainer is online now
Old 02-17-2018, 12:02 AM   #2
View Don Sims's Gallery114
Friends: (40)
Looks like a nice plane. Hope it flies as nice as it looks.
Don
Old 02-17-2018, 05:41 AM   #3
F22trainer
I've seen one fly flawlessly at our club, and I've seen the nose heavy issues some have had. AMA had a great review and correction without adding weight. Our member said he had easily 200 flights on his and flies it nearly everyday, so I'll pick his brain a little more on the balance. His flies super smooth and he does agree the gyro is probably the only reason he can fly it so well.
Old 02-22-2018, 05:38 AM   #4
F22trainer
I did get the opportunity to ask more info from Ken on his PT-17. His is PNP, not a Spektrum AS3X / SAFE but does have an Eagle Gyro stabilizer. His comments - make sure battery is ALL the way forward and check CG and it shouldn't be any problem.
I plan to enable the SAFE select to keep the set up similar to the Cub using the DXe 6 channel tx.
Old 02-25-2018, 01:56 AM   #5
F22trainer
Default Couldn't resist..
A little scale like realism...
Old 02-26-2018, 03:15 AM   #6
F22trainer
Default Maiden went well
Got 2 landings and 1 takeoff, two batteries worth of fun in the pattern getting used to it. Got a little short video, but it was not worth posting as there was only a little yellow speck against a blue sky, and then Dave saying "...ok, you ready to fly it?"
I did have to add 2 oz. into the hollow cylinders even with the battery all the way forward. Still need to adjust the rudder a tish too.
Wind kicked up shortly after the last flight, so I was happy to load up with both nearly ready to go next trip.
Old 03-11-2018, 06:45 AM   #7
F22trainer
A few more flights - still flying with the SAFE mode and avoiding the x-winds. It seems to fight me on takeoff and landing with SAFE tempering use of rudder.
Old 05-10-2018, 03:25 AM   #8
F22trainer
Now I probably have close to a hundred flights on this bird. She is a favorite of mine and the club. She has a little rash and I found the barrier fence when Xwinds got the best of me, but nothing high speed or real hard impact with a post. I did apply Polycryllic over the whole thing - 2 coats and it is still turning the same 11x7 prop she came with. Wind slammed it into the pavement today, about foot off the deck on landing - struts did their job. Taxi over to the pit, check her over good and the take her around the pattern one more time for a greaser landing with 7-10 knot headwind.
She has some company now -another looker moved into the hangar.
File Type: jpeg 2DF17D33-2175-4884-97DA-4108A4E89FA7.jpeg (1.67 MB, 15 views)
Eflite Whipit UM DLG!! Rockin Robbins Hi-Performance and Sailplanes 52 09-07-2016 11:03 AM
Eflite 60 amp ESC ...older...not PRO.....Programming Help flyinwalenda Power Systems 6 09-24-2013 09:38 PM
For Sale Apprentice 15e by eFlite RWF Airplanes - Electric For Sale & WTB 2 04-22-2012 04:32 PM
E flite Nieuport 17 modified build... dcwwcp WWI Era 24 06-17-2011 01:38 PM
Eflite Pt 19 450-which motor, servos, esc from Hobby King mxaexm Scale E-Powered Aircraft 2 02-12-2011 07:33 AM
Page generated in 0.11853 seconds with 41 queries
