What kind of charger should I buy for my battery?
Old 08-27-2019, 09:30 AM
Bobbyra
Bobbyra's Avatar
Default What kind of charger should I buy for my battery?
Hi everyone, recently I bought a smart battery TI22000 from MMC and its specifications says below:
Nominal Voltage—22.6V
Nominal Capacity—22600mAh
Charging Voltage—26.1V(4.35V/Cell)
Charging Current—20A
Working Temperature(discharge)— -10℃-60℃
Working Temperature(charge)—0℃-45℃
Storage Temperature— -10℃-35℃
Weight—2.7kg±0.1kg
Static Power—30uA
Dynamic Current—10mA
What kind of charger is best for this battery?
Bobbyra is offline
Old 08-27-2019, 06:20 PM
That;s a 6S Lithium Polymer High Voltage battery ... commonly termed LiHV.
Its says charging current 20A ... which is just under 1C (1C = 22.6A as per the capacity 22600mAh).
The charger you need is any that is capable of 6S LiHV packs and to deliver significant amp rate.
The 1C rate for that pack is as said 22.6A and at 26.1V = 500W capability.
Look for a programmable LiPo / LiHV charger capable of 6S and more than 500W for optimum charge.
Note - that any charger capable of charging 6S LiHV will do the job - but lower wattage means LONG LONG charge times !!
Old 08-28-2019, 04:09 AM
Bobbyra
Bobbyra's Avatar
Thank you buddy.
Bobbyra is offline
Page generated in 0.07901 seconds with 9 queries
