Wood Filler or Spackle?
Old 12-06-2008, 10:56 PM
Forge
Forge's Avatar
Default Wood Filler or Spackle?
Guys,
I am working on a kit build P-51 from MM. I am trying to fill and smooth out some transitional surfaces on my build. They will be covered with solite covering after my fixes.
Its it better to use a wood filler or wall spackle to fill, sand and cover? I just want to make sure that it will work well and look good when I cover over it. I don't have very much build experience and want to get it right the first time.
Then again, maybe either will work?
Thanks!
Forge
Forge is offline
Old 12-06-2008, 11:24 PM
darylm44
darylm44's Avatar
I would use light weight spackle. It sands easily and is really light.
darylm44 is offline
Old 12-06-2008, 11:25 PM
Originally Posted by Forge View Post
Guys,
Thanks!
Forge
Hi, get yourself some lite weight Spackel, it works great, and to fill large voids, mix with 5 min epoxy 50/50, hope that helps, Chellie
Old 12-06-2008, 11:27 PM
Hi Darylm Great Advice Take Care, Chellie
Old 12-06-2008, 11:33 PM
Forge
Forge's Avatar
Chellie,
Thanks once again for the great insight. Of course I have two tubes of wood filler in my tool box and no spackle. Murphy's law prevails again.
I need get some anyway for some walls in the house.
Have a great evening!
Forge
Forge is offline
Old 12-07-2008, 01:46 AM
Voyager2lcats
Friend Across the Water
Voyager2lcats's Avatar
Forge, light weight vinyl spackle is the "bondo" of the electric RC world.
Voyager2lcats is offline
Old 12-07-2008, 02:28 AM
CarpenterDave
RC Plane builder/flyer
Bad for Rc planes---- (Good for walls)
Name:	Bad for RC.jpg
For Rc planes----- these types
CarpenterDave is offline
Old 12-07-2008, 04:05 AM
groundrushesup
groundrushesup's Avatar
Attachment 85876
Attachment 85877
Yeap. And just a heads-up - I saw the smaller size of the lightweight Fast 'n' Final at my local Wal-Mart. Quart tubs at the Home Cheepo.
GRU
groundrushesup is offline
Old 12-07-2008, 07:56 AM
Thank you Voyager See I learn something new every day here, Take care, Chellie
Old 12-07-2008, 02:08 PM
Forge
Forge's Avatar
Attachment 85876
Attachment 85877
CarpenterDave,
Thanks for the photos! Not to be ignorant, but besides the packaging what makes one better than the other. Is "vinyl" the operative ingredient?
Thanks for all the great info.
Good flying.
Forge
ps. I was going to go out flying this morning, but we got about 3 inches of snow here in CT last night. I think my next mod or build will be to put skis on one of my planes.
Forge is offline
Old 12-07-2008, 06:37 PM
Voyager2lcats
My pleasure Chellie. You help me, I hope I help you. It was very nice of your club to accept me as a "charter" member being as I am in the "other" SC. You've got a great group in the Chino Renegades.
Old 12-07-2008, 07:38 PM
darylm44
darylm44's Avatar
I guess I am the chopped liver of these boards compared to Chellie (the "phillip minon" here). I give the first appropriate answer and she gets all the accolades Now why would that be?
I am not as fun to flirt with you think
Have a great day, I am going to sulk my way off to the field where I am going to fly with skis in a freezing rain. Yes, we are having another Alaska Fun Fly
Daryl
darylm44 is offline
Old 12-07-2008, 08:44 PM
CarpenterDave
CarpenterDave,
The sheetrock lightweight joint compound, almost allways called "spackle" is very heavy, loaded with water, and harder to sand when compared to the Dap, Red Devil, etc. brands of lightweight patching spackle.
When you go to your local hardware or home center you will feel a big difference between the two--in the same sized containers.
Darylm44 said what is best to use, I just wanted to show a picture so people are not confused between the types of "lightweight spackle".
Old 12-08-2008, 02:43 AM
starcad
Model Designer
starcad's Avatar
And another follow up on the Light Weight DAP spackle. With that, wire ties, dry wall screws and duct tape you can build a city.
Seriously, I always have a quart in my shop. If it gets a little dry just add a couple of drops of water.
starcad is offline
Old 12-09-2008, 05:44 PM
riverrat
circa: 1946
riverrat's Avatar
Question
I learn something new here every day!!
Dap Lightweight Spackling! Sounds great!!
Is there a limit to the max thickness that can be applied? As in streamlining, maybe scratchbuilt in & out air scoops? And can a lite coat of CA glue be applied over it to seal & harden, after sanding to shape?
Been using Hobbylite on very small & shallow fixes, works good, dries fast, & very easy to sand. But in my opinion, it's a little to soft for any thicker application.
Jimmy
riverrat is offline
Old 12-09-2008, 05:51 PM
Bub Steve
Bub Steve's Avatar
Jimmy
1/8"-1/4" max without checking,(crack'in) you can do more in layers, bub steve
Name:	petty an red 695.jpg
Bub Steve is offline
Old 12-09-2008, 07:31 PM
RickAvery
One bit of caution when using the lite spackle. Because it is VERY light, it can take a bit of finesse to sand without the joint showing. I use it all the time and when possible, especially when filling a wide gap or joint, I use a block to keep from hogging out the fill with uneven pressure from my fingers behind the sand paper. It sands even faster than many foams or balsa. I then seal it with a few coats of minwax polycrylic with a light sanding between coats. Mind you, I'm usually painting it & not covering it. GreaT stuff!! Good luck.
Rick
RickAvery is offline
Old 12-09-2008, 07:48 PM
riverrat
circa: 1946
riverrat's Avatar
Thanks!!!
Rick & Steve!!
Jimmy
riverrat is offline
Old 12-09-2008, 08:10 PM
groundrushesup
one more handy dandy tip:
If you are working with raw EPS that has a pronounced bread pattern, you can - rather than sanding away material to smooth some of the more egregious features - mix this lightweight spackle with water into a pancake-batter-ish consistency (I call it a 'slurry') and brush it on. let it dry a few days, and then sand away - you're foam will come out baby's butt smooth. Great step before 'glassing' with YMOC (your material of choice) and Water Based Polyurethane (MinWax Polycrylic is favorite).
I also used this technique to bury rudder and elevator control rod tubes in a foam fuselage, then covered out with spackle and sanded - hard to tell they are there.
Old 12-09-2008, 08:12 PM
Bub Steve
Bub Steve's Avatar
Good one GRU Bub! steve
Old 12-09-2008, 09:17 PM
phupper
Flyin' Phup
phupper's Avatar
"mix this lightweight spackle with water into a pancake-batter-ish consistency (I call it a 'slurry') and brush it on"
I got this tip from GRU a while back and made my own version. I spray the foam with water, wipe off the surface drops, then apply the spackle.
Besides the final smoothness, I think the thinned spackle penetrates deeper into the foam giving it a better grip. It does take a little longer to dry though.
Phil
phupper is offline
Old 12-14-2008, 05:17 AM
Prof100
Attachment 85876
Attachment 85877
Excellent visual aid!
Prof100 is offline
Old 12-14-2008, 05:21 AM
Prof100
Another filling option is Water based polyurethane (Minwax) mixed with baby powder. Dries well and is very easy to sand.
Prof100 is offline
Old 12-14-2008, 05:26 AM
Voyager, Your Family here Take care and Stay Sweet, Chellie
Old 12-14-2008, 05:50 AM
Voyager2lcats
Default Third Option: Spackle and WBPU
Hey Prof100, I follow the Grasshopper/PD1 approach: spackle and WBPU+silk. It's like a slightly spongy armor.
Quick Reply: Wood Filler or Spackle?
Page generated in 0.14814 seconds with 14 queries
