Keeping Prop on airplane HELP!!!
Old 09-18-2008, 02:25 AM
Jim52519
Default Keeping Prop on airplane HELP!!!
I have a Hanger-9 .46 size Sundowner. I have an E flight 46 to power it. The prop drive hub is a collet arrangement. Is ther a trick to keep this on the motor shaft? Twice I have lost the prop and hub in flight , never to be found. Tonight it happenrd and it did some damage to the wing. Would loctite help? Are there better prop hubs? HELP!
Thanks,
Jim
Jim52519 is offline
Old 09-18-2008, 02:34 AM
Dr Kiwi
Are you sure you have the correct size collet adapter? If you crank the proper collet down with a socket wrench, or a decent length bar if it has a cone nut... it should hold well.
Dr Kiwi is offline
Old 09-18-2008, 02:35 AM
fr4nk1yn
^_^
fr4nk1yn's Avatar
is this the SAME collet?
Try a different one of different manufacturers. I never have a collet come off in flight.
fr4nk1yn is offline
Old 09-18-2008, 03:37 AM
Thanks,
Jim
are you using the E Flite collets, if you are, get away from them, and buy a decent collet prop adapter, I have had nothing but problems with them, take care, Chellie
Old 09-18-2008, 03:47 AM
Tony G
I have also had an issue, confirmed by my LHS as a general weakening of cheap metal the more times you crank them down. I've gone to a standard size, causing me to ream the APC props, but have found it much better.
Tony G is offline
Old 09-18-2008, 05:08 AM
groundrushesup
groundrushesup's Avatar
Great Planes makes a decent one - they also go to the trouble of putting "APC ready" on the package so you know it will work with the APC-E's rather large/deep prop hub.
groundrushesup is offline
Old 09-18-2008, 02:26 PM
Dr Kiwi
Anyone know where Sierra Hobby (Perfect Prop Adapters) has disappeared to?
Dr Kiwi is offline
Old 09-18-2008, 02:30 PM
Here you go Dr. Kiwi
http://www.visionhobbies.com/1284485.html
Old 09-18-2008, 02:33 PM
I dont know if this is the hobby shop or not that your looking for, take care, Chellie
http://www.highsierrahobbies.com/
Old 09-19-2008, 03:10 PM
Walt Thyng
Walt
Walt Thyng's Avatar
I've lost several prop/adapter/spinner combos because i had the brake on. Unless you'e flying a folder or have some very special need for it, disable the brake or go to a soft brake.
Walt
Walt Thyng is offline
Watt Flyer Plane Guide
03-27-2008 06:41 PM
gorfllub
07-18-2007 10:25 PM
darkside212
04-07-2007 02:57 PM
SilberIgel
04-16-2006 02:41 PM
markus
09-18-2005 10:34 PM
Quick Reply: Keeping Prop on airplane HELP!!!
Page generated in 0.09656 seconds with 13 queries
