Foam Safe Cleaners and Solvents - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 09-09-2013, 05:19 AM
Default Foam Safe Cleaners and Solvents
OK I know about glues, but what about solvents to clean up glue joints or runs?
I know acetone is out.
dereckbc is offline
Old 09-09-2013, 05:49 AM
Depends on the foam and the finish used (if you don't want to take the paint off)
If using a water based glue then use a damp paper towel or similar.
Whatever solvent is in the glue is what you use. For Epoxy use denatured alcohol (and get it before the epoxy starts to stiffen)
For general cleaning of the models I use foaming bathroom cleaner... after testing on scrap foam... since the bubbling action can lift dirt out of the little crevices between beads of EPO or EPS. I haven't had much luck cleaning EPP.
Old 09-09-2013, 06:08 AM
THX yeah those two I know, I should have been more specific. What to use on CA? I know Acetone dissolves CA, but also the foam with it.
dereckbc is offline
Old 09-09-2013, 08:31 AM
Water eventually dissolves CA... it can take a very long time though.
If its normal CA and that didn't eat the foam then you are may be dealing with EPO If so, carefully flex the area (to avoid permanent deformation) and the CA will pop off. EPO is the next best thing to Teflon. Nothing really bonds to it. Some glues stick well enough to fly but you can disassemble it every time.
Old 09-09-2013, 09:33 AM
I use Rubbing Alcohol on Depron to remove the Release agent that is on the foam so glue, paint and stickers will attach to it, test on other foams, test a CA de bonder on foam to see if it wont desolve it. Take care, Chellie
Old 09-13-2013, 10:30 PM
Bill G
Super Contrubutor
Bill G's Avatar
You could try testing a small, inconspicuous area with Testors enamel or airbrush thinner to see how it behaves.. A relatively fast wipe done without soaking the foam has worked for me, without eating foam.
Bill G is offline
Old 10-11-2013, 09:24 PM
Epoxy - Parafin / Kerosene / De-natured alcohol
CA - De-bonder but better is your Wife's Nail Polish Remover ...
Water based glues - Wet cloth but with PU (GG) only when fresh ... as it reacts it will resist stubbornly.
PVA (White glue) - water
Contact glue - Paint thinners / acetone
ALL the above save the water based need testing on scrap foam first ... any petroleum based will eat many foams as will acetone, Nail Polish remover etc.
Old 01-13-2018, 08:09 PM
TimMarkham
I have a Flyzone Seawind that is Brand New. It has been in the basement for a year now. It has greyish discoloring to it. I need to know what to use to clean it. I have tried 409, bleach & water, and rubbing alcohol. None of this worked for me. Any help would be great.
TimMarkham is offline
Page generated in 0.09091 seconds with 12 queries
