Motor power turns on or revs up when signal is lost.
Old 02-17-2008, 11:11 PM
eflyingman
Default Motor power turns on or revs up when signal is lost.
Hi. Of all my receivers, one, upon loss of signal, seems to turn on a stopped motor, or randomly rev up a slowly spinning one. And once signal returns, it doesn't turn the motor back to the setting it was at before, but keeps it at the new setting. You can throttle up, and the motor spins up, but throttling down does not stop the motor. I have to unplug the battery and replug it in to reset.
The receiver is a JR RS6UL, the ESC is a Phoenix 25, and the motor is a Medusa 28-32-2800. If I swap out the receiver for another, the system behaves as expected: Loss of signal = motor shut-off.
As far as I know the JR does not have a failsafe or any lost signal features.
Is this a bad receiver or is there something I am missing?
eflyingman is offline
Old 02-17-2008, 11:26 PM
Lloyd
Lloyd's Avatar
Default motor revs when signal lost
Always, always unplug the battery from the esc prior to turning off the transmitter. If you don't you will get hurt or hurt someone.
Lloyd is offline
Old 02-18-2008, 04:37 PM
Rodneh
As stated in other posts, any and all receivers can and may react to noise (and there is always electrical noise in all areas, some more than others) and you can not predict what kind of output your receiver will give in the absence of a proper signal unless you have one you can program for a failsafe condition where you have preset the throttle to "OFF" on loss of signal. This is true for just about any type or design of receiver.
Rodneh is offline
simibill
02-18-2008 12:33 AM
trooper8
11-01-2007 03:35 AM
lennyshotgun
09-06-2006 08:25 AM
remoz54
03-18-2006 10:11 PM
remoz54
03-18-2006 07:47 PM
Quick Reply: Motor power turns on or revs up when signal is lost.
Page generated in 0.07385 seconds with 13 queries
