Sterling Mambo 48" Electric Powered - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 11-01-2018, 02:01 AM
E-Challenged
E-Challenged's Avatar
Default Sterling Mambo 48" Electric Powered
I flew a full size Sterling Mambo with single channel rudder only system with rubber wound escapement and .23 glow power back in the 60's and had limited success with it, enough to become nostalgic and to want to build one with electric power.
I downloaded Mambo plans from Outerzone to a flashdrive and took it to a Fedex central office to have plan sheets printed full size. I obtained a Tobe Galloping Ghost actuator from Jay Mendoza in Mission Viejo, CA to give me flapping rudder and elevator. Elevators were added onto the lifting stab. I installed a Scorpion 450 size brushless motor and 3S 2200mah lipo . I added a 2 ounce fishing weight to the nose next to the motor. The model flew but the small Tobe GG actuator was not powerful enough and the model was barely controllable. I removed the GG actuator and installed two small servos to operate rudder and elevator. I grafted on balsa to increase area of the elevator.
The model now is very controllable and loves to crawl along in thermals. Model has translucent red wings and stab and yellow doped slab balsa fuselage and vertical tail. It has original Sterling wing logos made by Callie Graphics . The tail skid makes taxiing "interesting"
E-Challenged is offline
Old 11-01-2018, 04:35 AM
Jack_Hammer
Veteran USAF
Jack_Hammer's Avatar
Did you print out the Mabo graphics on paper and cover with clear foil?
Jack_Hammer is offline
Old 11-01-2018, 03:37 PM
Stick Dude
Stick Dude's Avatar
I like that see through monokote, it offsets opaque pretty nicely, and you can see the construction of the airframe fully, really unique!
Stick Dude is offline
Old 11-01-2018, 03:56 PM
Takes me back !! Super 60's and all that in UK.
Nostalgia is great but I can still remember some of the heartbreak when a model failed to fly well and crashed !
I have memorys of my older brother 'forcing me' me to be the runner to tow up his free-flight gliders !! Beautiful tissue covered jobs ... never did fly well though !
Pulse radio / GG and escarpments ............ what a joy when 2ch proportional hit the counters !!
Old 11-01-2018, 09:59 PM
E-Challenged
I downloaded the Sterling Mambo graphic logos and had Callie Graphics create the proper size logos to fit the wing. Callie is a lady who can make up almost any graphic you might need for a scale or sport model . She only needs some basic info and her prices are very reasonable. For example she made the Pepsi-Cola graphics for my Pat Tritle Stinson Reliant based on a 1937 Pepsi executive/PR aircraft. She made me a complete set of graphics for my Pat Tritle DC-3 in AA Flagship Detroit livery. Her graphics are stick-on vinyl, easy to apply.
Old 11-01-2018, 11:18 PM
Brner
AMA16634
Default Memories....
Brings back memories....The Mambo was my first RC (sort-of) plane, back in 1956. It held a twin needle K&B .15 (one for high speed and one for low speed) Never did get that worked out. Hacked together a kit radio (Ace Commander) and, with a rubber wound Vari-comp ESC interrupted the Mambo's flight path often. Seems like centuries ago....Those were the days you had to work to get a plane in the air.....
Transmitter below is the one I built but rec and esc are more modern....LOL...
Brner is offline
Old 03-26-2019, 06:33 PM
Mooney_Driver
The Mambo was my first attempt at building an RC model in 1965. As a young kid I did not have money for a radio. I would like to build another one. What electric is being recommended for that?
Thank you.
Mooney_Driver is offline
Old 06-19-2019, 04:57 PM
E-Challenged
Model requires very little power . Mine uses a Park 400 size brushless motor and a 3S 2200mah lipo, 25amp speed control. Loves to thermal. Rudder and elevator on HS-55 servos.
06-28-2017 04:22 PM
01-09-2017 02:23 AM
11-02-2014 01:32 AM
Fon
07-17-2013 10:55 PM
Quick Reply: Sterling Mambo 48" Electric Powered
Page generated in 0.10114 seconds with 19 queries
