Old 03-12-2018, 02:58 PM   #1
Vinny7636
Vinny7636's Avatar
Club: DE R/C --Salem County N.J.
Default Twin Engine ESC & Engine Questions
Hello to all,
I could use some help please with Engine & ESC selections.
I have a wooden kit, twin engine Cessna Bobcat, 85" WS, it should end up approx 17 to 25 lbs.
Being a twin engine model I am reluctant to power this plane with twin gassers. I have 2 zenoah g23's but feel this AC would live longer on E power,
Attached you will find a simple schematic with my calculations after doing some research. You will find that I have 1 ESC controlling both engines, I was going to use 2 separate ESC's, but I have an Hobbywing 150A OPTO and would like to use it , not sure if this will work?
1 Estimated Flying time with 2, three cell 5000 mah batteries?
2 Will power distribution to engines be balanced with this set up? Anybody tried this before?
3 If I use 2 ESC's, would two 80 amp ESC's suffice with the Turnigy engines selected? If not is there any balancing devices or different wiring I can use?
3 With twin AC can you split the wattage by 2? Therefore an AC requiring 2000W, you can power it with two 1000W engines.
4 Do you think the Turnigy engines I selected will give this AC a medium performance?
I greatly appreciate any input and your time...
Thanks to all, Vinny
Name:	E Power.png
Vinny7636 is offline
Old 03-12-2018, 05:30 PM   #2
Stay Quiet
Stay Quiet's Avatar
Club: Campobello Flyers
Some say it can be done, but others will warn it can mess up the timing of the motors, or fry the ESC.
I built a twin using two 3s lipos connected in parallel, with two ESCs connected to the Rx with a Y harness, and it worked great. To keep the motors in synch, I made two extension leads pretty much the exact same length.
Stay Quiet is offline
Old 03-12-2018, 05:40 PM   #3
Vinny7636
Vinny7636's Avatar
Cool, yes I'm heading in that direction using 2 esc's. I have the one, 150a esc and wanted to us it, but they no longer manf. that model.
thanks, vinny
Old 03-12-2018, 07:09 PM   #4
View firemanbill's Gallery67
Club: Smoky Mountain Aero Club
Friends: (64)
I have never seen anyone be successful running two brushless motors on one ESC. Not saying it can't be done, I just have not personally seen that work.
I had a Eflite EDF Airiner and used two separate ESC's and SQ said, tried to keep the leads all about equal length.
President - Smoky Mountain Aero Club, Sevierville Tennessee
Old 03-12-2018, 11:33 PM   #5
Stay Quiet
Stay Quiet's Avatar
thanks, vinny
Not sure what motors you intend to use, but HURC sells some 100 amp OPTO units that are very affordable:
http://www.headsuphobby.com/Sky-Powe...EC_p_1815.html
Old 03-13-2018, 01:42 PM   #6
Friends: (17)
One ESC will not run two motors properly.
If the two ESC's have BEC's built in - linera BEC's are fine both working - but SBEC's are recc'd not to be both connected ... pull red lead of one ...
(I have connected both SBEC's on my Concorde and TU144 models without problem).
I have twin models with parallel and separate batterys ... of course parallel should be better so that both motors reduce together due to battery power going down...
Its also worth thinking about differential throttles ... basically both controlled by one stick .. but rudder altering the motors to create a yaw effect .. my Lancaster has it (ok its 4 motor but principle is same) ...
Old 03-13-2018, 08:33 PM   #7
Vinny7636
Vinny7636's Avatar
So being a novelist with twin E's, I am assuming that you mix throttle and rudder? How do you program that or do you hook esc in different channels on the Rx? Would your rudder trim be used as a balance?
Old 03-13-2018, 09:15 PM   #8
Friends: (17)
Answered other thread.
Old 03-14-2018, 07:02 PM   #9
Kosh
Kosh's Avatar
View Kosh's Gallery82
Club: NWEF.ORG
Send a message via Yahoo to Kosh
100mph Speed Demon  AV Contest  AP Contest Winner
Friends: (31)
Use a V-Tail mixer hooked to throttle and rudder.
I have flown 3 planes with twin brushless motors on a single ESC that worked but these were low kv and less than 10 amp draw. I would not recommend it and here why. Both motors seem to start fine and work but in the air closing the throttle and restoring power at times you would get one motor cogging or stuttering. While it was just a matter of hitting the throttle again to make them sync its really not something you want to deal with while flying.
Wattflyer, Where your friends are.
http://www.youtube.com/SeattleKosh
Kosh is offline
Old 03-14-2018, 07:34 PM   #10
Club: www.rmvc-cumulus.nl
Two active threads, same subject.
Continue in the thread with most replies?:
Twin Power Question/Help 85" Cessna Bobcat Build
Vriendelijke groeten Ron
Without a watt-meter you are in the dark, until something starts to glow
e-flight calculators watt-meters diy motor tips Cumulus MFC
100+ MPH Club CHELLIE Hi-Performance and Sailplanes 2014 02-25-2018 11:51 AM
Motor / ESC and various other newbie questions spaten Beginners 6 01-09-2011 03:07 AM
Motor / ESC and various other newbie questions spaten Power Systems 21 12-30-2010 11:20 PM
Page generated in 0.14159 seconds with 42 queries
