Corona Rx - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Corona Rx
Old 07-16-2007, 12:46 PM
Micro_R/c.co.za
Default Corona Rx
Need some help... Can I use any crystal with the CORONA range of Esc's??
Micro_R/c.co.za is offline
Old 07-16-2007, 12:54 PM
Micro_R/c.co.za
Sorry, I MEANT RX's
Old 09-09-2007, 01:16 AM
franklin_m
franklin_m's Avatar
Default My experience w/ Corona
Hi,
Not sure if this answers your question or not, but it at least gives you a data point.
I've got a Corona 620, the six-channel dual-conversion model, for Futaba radios. My transmitter is a 6EXAS. I first put the Corona crystal in the thing and had real range problems. I called BP Hobbies, from whom I purchased it, and they recommended that I try a Futaba Dual Conversion Crystal. I did so and had immediate double or even triple the distance during a range check.
So, for the 620 at least, a Futaba dual conversion crystal seems to work just fine (better in fact).
Frank
franklin_m is offline
Old 09-12-2007, 06:38 AM
Bill G
Super Contrubutor
Bill G's Avatar
Originally Posted by franklin_m View Post
Hi,
Frank
Same type issue may be true with the micro Coronas. I only have one, and can't remember what type crystal it has (bought with it) but if its a UM1, then the Berg would probably be better. From what I hear, they are the highest quality UM1 crystals, and will add substantial range to the GWS pico and naro receivers.
Bill G is offline
Old 11-25-2007, 05:33 AM
Radbuster
Park Flyer
Radbuster's Avatar
Cool Range Check
I just bought a Corona 620. The specs say to range check the thing (antenna down) out to 270 feet! Whoa; I thought 100' was the usual. What distance are people using to range check?
Radbuster is offline
Old 11-25-2007, 05:46 AM
Hi I bought 2 corona receivers, 4 channel single conversion, the range check on mine was very poor, and glitched a lot, with the corona crystal, I Think i will stick to the Hitec Mirco receiver 05s 5 channel receiver, anyone want to buy 2 new corona receivers 4 channel, single conversion, CHEAP, Chellie
Old 11-25-2007, 11:14 PM
Radbuster
Park Flyer
Radbuster's Avatar
Chellie;
Based on Wattflyer advice, I put in a Futaba Xtal in the Corona 620. Range checked it OK at 150'. It flew fine, but I didn't take it out more than 1/4 mile.
Old 12-14-2009, 02:09 AM
babylon5
May I know how good is this Corona CR8D receiver?
It is version V2
See attachment
babylon5 is offline
Old 01-17-2010, 06:10 AM
Radbuster
Park Flyer
Radbuster's Avatar
I've switched to Corona synthesized RX's and have had very good luck with the RP4S1. I use that on all my planes.
dchaf
49
05-17-2008 12:07 PM
gsmena
California
03-25-2008 05:17 AM
shane.barton
10-15-2006 10:58 AM
Hammmike
Standard & Large E-Heli Talk
14
02-17-2006 12:37 AM
xrbcoronalogoflyer
09-11-2005 11:04 PM
Quick Reply: Corona Rx
Page generated in 0.06833 seconds with 15 queries
