COG seems well out using cog tool. NEED HELP!!!!!
Old 10-15-2012, 07:46 PM
npowell28
Default COG seems well out using cog tool. NEED HELP!!!!!
Attached is a picture of my 54 Inch cargo type plane. I've just used the COG tool at this page
http://adamone.rchomepage.com/cg_calc.htm
Using this tool puts the COG about an inch behind the leading edge. This seems mad to me. I'm having to put the batterys about 4-5 inches behind the leading edge to just get the balance. From what i've experienced and read in the past the COG is normally 1/4 to 1/3 of the Root chord measured from the leading edge.
What do you guys think?
Neil
Name:	c130 replica.jpg
ID:	163452   Click image for larger version
npowell28 is offline
Old 10-15-2012, 08:04 PM
npowell28
Forget this one guys. I've sorted it. I won't embarass myself too much other than to say i really should check my measurements.
Thanks all the same
Old 10-15-2012, 08:12 PM
I'm confused as to the problem.
1" behind the LE would appear to be further forward that the 1/4-1/3 rule of thumb predicts (I assume the wing chord is more than 4"). And I cant understand how the plane could be balancing that far forward if the battery was installed 5" back from the LE Do you have a big heavy piece of kit in the nose?
It may be helpful if you posted all the necessary dimensions to plug into the calculator.
PS.. I take it that you know that the flaps and ailerons need to be included in the wing chord dimensions?
Old 10-15-2012, 08:14 PM
Sorry, i was typing when you posted your follow up...
Old 10-15-2012, 08:20 PM
npowell28
no probs. I did mean 1 inch behind the TE not the LE. I'd made a mistake in my measurements. I did all the measurements in mm but did the stab measurement in cm's e.g 30 in stead of 300. I've adjusted it now and it comes back fine.
Old 10-18-2012, 03:14 PM
npowell28
Right thats that sorted. Nicely balanced now.
Mental note. Check measurements in future
Old 10-18-2012, 09:21 PM
Yakfishingfool
damn metric system....
Yakfishingfool is offline
Nidge
10-07-2012 03:28 PM
npowell28
04-19-2012 06:13 PM
Humor
12-03-2011 03:11 AM
SpaceFuzz
Batteries & Chargers
07-11-2011 04:51 PM
Alabama Flying Dude
Electric Ducted Fan Jets
04-05-2011 07:41 PM
Quick Reply: COG seems well out using cog tool. NEED HELP!!!!!
Page generated in 0.10306 seconds with 16 queries
