Servo testing
Old 02-26-2011, 03:02 AM
crobar
crobar's Avatar
Default Servo testing
Does anyone have a simple way to test servos without a receiver before installing them? What kind of power source etc.
crobar is offline
Old 02-26-2011, 03:11 AM
I've designed and built up several servo testers over the years, using a microcontroller. Circuitry is quite simple, microcontroller is not. It must be programmed. But the circuitry is simple as it can get.
I think there are several servo test units in the internet, you might try googling servo tester and see what you get.
Found this one:
http://www.york-electronics.com/
Old 02-26-2011, 03:18 AM
BEAR-AvHistory
RDRC
BEAR-AvHistory's Avatar
About $5 - will do 3 at a time
http://www.hobbycity.com/hobbycity/s...idProduct=8296
BEAR-AvHistory is offline
Old 02-26-2011, 03:20 AM
+1 - I use the York servo tester. It saves me countless hours of work on servo setup. They are great for finding binds, improper linkage setup, proper control throws so many things. It is fantastic, worth three times what it costs.
I also like that I can use it to cycle new servos for 5 minutes or so. It is a great test feature.
I don't know why more folks don't use them.
Old 02-26-2011, 03:41 AM
Grasshopper
Some Assembly Required
Grasshopper's Avatar
Same here. I use the servo tester and hook it up to a little 5 volt wall wart I had laying around. I soldered a servo connector on the end of the wall wart lead so it plugs right in to the servo tester.
Here's the one I use. $8.41 with free shipping.
http://www.dealextreme.com/p/e-sky-e...icopters-15594
Grasshopper is offline
Old 02-26-2011, 04:01 AM
Just a note:
For other wattflyer readers, make certain that wall wart has a regulated 5 volt DC output. Some of them are nothing more than a transformer, with a bridge rectifier and capacitor. The output voltage of these things vary all over the map, depending on servo loading. They could exceed the safe maximum voltage rating of your servos.
Easy to check, just plug in the wall wart, and put a digital voltmeter across the units output wires. If its output is regulated at five volts, you should measure 5.0 volts DC. If it's 6 or 7 volts, or more, don't use it on servos.
Past President of PSSF
I use this one http://www.bphobbies.com/view.asp?id...7&pid=D0736126
It has 4 AA batteries inside, but you can power it externally.
It has more features than just moving servos, it can measure the pulse coming out of your rec. and will read RPM, + others,-- total 7 things
Mine is so handy while setting up a plane, that it lives in a drawer just under the counter.
Wildflyer is offline
Old 02-26-2011, 04:03 AM
Grasshopper
Just a note:
Thanks for the tip. I'll have to check that out. I've been using it for a couple of years with no problems but that doesn't I haven't just been lucky.
lakeside1000
Delta & Flying Wings
9
12-29-2011 05:49 PM
terrynshed
02-04-2011 09:33 AM
nz builder
02-02-2011 07:14 AM
terrynshed
11-19-2010 08:48 PM
Quick Reply: Servo testing
Page generated in 0.09975 seconds with 13 queries
