twin boom help
Old 05-21-2010, 02:58 AM
hillbillynamedpossum
Rode the short bus
hillbillynamedpossum's Avatar
Default twin boom help
Im looking into building a twin boom pusher. Id like to put some numbers forth in an effort to save a few crashes and disappointment.
wing span.....32"
root chord.....8"
tip chord......6"
sweep.........2"
stab root chord 4"
stab tip chord...4"
stab sweep.....0"
stab span.......12"
distance between l/e's 20"
im looking at about 16-24 oz all up
I plan to use a fullflying tail with a pivot 1" from the l/e to the center line of the pivot.
I plan to use a pull pull setup on the tail and rudders......maybe even the ailerons if I can figure it out.
Im putting a speed 400 from Jeff and a 3s lipo on this.
So.....hows these numbers look?
Possum
hillbillynamedpossum is offline
Old 05-21-2010, 04:25 AM
Sparky Paul
Sparky Paul's Avatar
Other than appearing a bit smallish wing area wise... OK.
I'd go for 36" span.
Done a few twin-booms... but using 2M wings for larger airplanes overall.
The booms have to be stiff to resist bending.
There's a lot of download on the horizontal which can bend the booms down with increasing airspeed, which will force the plane into a dive.
Lost the third in the photos that way.
ID:	128159   Click image for larger version
ID:	128160   Click image for larger version
Sparky Paul is offline
Old 05-25-2010, 04:10 AM
Rode the short bus
I like the wierd V-tail.....whats that called Sparky?
I got a good start on things. I had a hard day today, and barely had a chance to fly.
I went with a 36" wing.
Possum
Crash9
Aerial Photography
82
12-12-2010 08:12 PM
neilg.
General RC E-Heli Talk
07-30-2008 01:36 PM
RickSavage
E-Flite Helicopters
05-07-2008 05:58 AM
moodier
04-05-2008 04:16 PM
GreenAce92
14
02-08-2008 02:54 AM
Quick Reply: twin boom help
Page generated in 0.06285 seconds with 13 queries
