Larger tip airfoil, smaller root airfoil
Old 05-08-2010, 07:57 AM
Huffy01
Huffy01
Question Larger tip airfoil, smaller root airfoil
I recently bought a CD of 1000's of aircraft plans from ebay.
I found this plan interesting but would like to slightly modify the build.
The main "thing" I was think of doing was the wing.
It uses a constant size chord for the airfoil with a shaped aileron.
I was think of using a different size chords to get the shape but was worried that having a thicker airfoil would give bad flight characteristics.
I thought maybe if the thickness of the airfoil may be better, having a thin/long airfoil on the tip and a fatter/shorter airfoil on the root.
Does anyone know if this would be a problem??
There is a copy of the plans on the post , "Der Slopen Stick".
File Type: pdf
Huffy01 is offline
Old 05-08-2010, 04:56 PM
Sparky Paul
Sparky Paul's Avatar
It looks like a drag farm in the original format. Constant chord thick wing.
Thin the entire wing section.
Tapering the wing will lose the basic "Stik" shape.
Sparky Paul is offline
Old 05-08-2010, 05:08 PM
Huffy01
Huffy01
I would like to keep the "Stik" look, thats the appeal too me.
I'd even like to add the dip's along the trailing edge to look like fabric tension between the ribs.
Huffy01 is offline
Old 06-17-2010, 09:26 PM
helidude12
helidude12's Avatar
sorry this is off topic, i was just looking around this forum,, but...Sparky Paul, I love your avatar, it is awesome.
helidude12 is offline
aero_k
3D Flying
05-15-2008 01:40 PM
cassat
Delta & Flying Wings
06-03-2007 11:27 PM
GreenAce92
Aerodynamics
05-04-2007 11:25 AM
Rickochet
04-11-2007 09:42 PM
normblitch
Vintage and old timer models
02-04-2007 01:44 AM
Quick Reply: Larger tip airfoil, smaller root airfoil
Page generated in 0.06792 seconds with 13 queries
