Hobby Lobby A-10 aerodynamics
Old 11-02-2009, 11:09 PM
martin_05
Default Hobby Lobby A-10 aerodynamics
I've been working on this new A-10...lots of mods
http://www.hobby-lobby.com/a_10_wart...71555_prd1.htm
The trailing edges on all surfaces were extremely thick (about 5mm) so I decided to sharpen them. After much careful sanding I brought them down to 1mm. The elevator and vertical stabilizers were easy. The wing required some care because it appeared to use an undercambered profile and I didn't want to mess with it too much.
The changes helped in a very visible way. The model flies a lot better now and low speed performance has improved significantly. I haven't takend the time to measure it yet but I know that I get more flight time because I don't have to be at full throttle all the time. It also carries more energy going into loops whereas before I had to be very careful about how to enter a large loop.
This model never really few very well when inverted. I am wondering what else I should look for in terms of build or design issues in order to fix this. When I roll it over it is really unhappy, requiring lots of aileron work to keep it there. Let's put it this way, I would not dare doing a low inverted fly-by for fear of putting it into the ground.
Any ideas?
Thanks,
-Martin
martin_05 is offline
Old 11-19-2009, 06:13 PM
Matt Kirsch
Matt Kirsch's Avatar
Martin, I think the undercambered airfoil is killing you with the inverted flight... You gotta push so much down elevator to hold it, that you're on the verge of a high speed stall all the time and that makes it unstable in roll.
Matt Kirsch is offline
DetroitHawk
Warbird Electrics
12-25-2009 09:44 PM
Flyboone
Hobby Express discussion
21
10-26-2009 02:04 AM
Matt Kirsch
Electric Ducted Fan Jets
07-16-2009 11:34 PM
fireflyer
04-12-2008 12:33 AM
PerlAddict
Basement Bargains
01-27-2008 12:34 AM
Quick Reply: Hobby Lobby A-10 aerodynamics
Page generated in 0.11689 seconds with 11 queries
