characteristics of this wing
Old 10-10-2009, 03:41 AM
Keith C
Default characteristics of this wing
How will this wing fly?
A/R is less than 2-1, 8.4 thickness, flat bottom,leading edge is carbon tube about 3/16 dia. Plane AUW is 16.5.
Thanks, Keith C.
Keith C is offline
Old 10-10-2009, 09:15 AM
Keith C
sorry guys, the total area is about 528.
Keith C is offline
Old 10-10-2009, 09:34 AM
slipstick
Some units might be useful ? 8.4, 3/16, 16.5, 528 what ?
I'm guessing 3/16 is probably inches but not so sure about the others.
slipstick is offline
Old 10-10-2009, 12:14 PM
Sky Sharkster
Sky Sharkster's Avatar
Default Low Aspect Ratio Wing?
Hello Keith,
To answer your question, not very well, I'm afraid.
An aspect ratio of 2:1 (or less) wing will have a very low L/D (lift to drag) ratio, far below a normal A/R of 5:1 to 8:1. Also the tip vortices and tip losses will be high. About the only thing a short, stubby wing has going for it is a faster roll rate, and possibly greater strength span-wise. http://www.lems.brown.edu/vision/peo.../Ch6_wing.html
Here's a graph showing how the maximum lift coefficient increases with increased aspect ratio + vice versa;
http://worldofaerospace.googlepages....t-RC-plane.htm
So, I believe a higher A/R would be a better aerodynamic choice.
Ron
Sky Sharkster is offline
Old 10-11-2009, 06:42 AM
As Ron indicated, on low aspect ratio (AR) wings there is a lot of drag (specifically induced drag) and the angle of attack required to produce a set amount of lift is higher than a 'normal' AR wing (this is what the graph was showing, the 'lift slope' of the low AR wing is shallower)
This mainly effects the model when it's being flown at a high coefficient of lift, i.e. slowly or pulling tight turns. When being flown quite fast and straight hence at low lift coefficient then low aspect ratio wings work ok.
Stall behavior of low aspect ratio wings also to be gentle and as Ron said they are usually strong.
Providing you have planty of power and dont expect a good glide then your low AR wing could work ok.. But something with a moderate AR would be much more efficient.
airwarriorhlbly
10-07-2009 04:42 PM
Monty777
E-Flite Helicopters
10
08-15-2007 07:10 AM
Dave R
Beginners - Helis
03-10-2007 10:28 PM
123Cat
3D Flying
05-31-2006 03:57 AM
Jeremy Z
Delta & Flying Wings
01-16-2006 12:33 AM
Quick Reply: characteristics of this wing
Page generated in 0.07163 seconds with 13 queries
