horizontal stab angle
Old 08-22-2009, 11:39 AM
Keith C
Default horizontal stab angle
I am building a plane with center pod and twin booms. the wing is glued to the pod with 2 deg. built in. 3 deg. dihedral.
I am ready to install the booms and stab.
Is level with wing centerline correct? SS airfoil. (Cut down old trainer wings.)
Can i run 2 rudders with one servo and "V" shaped pushrods?
Ailerons ,now on paper ,are 15 X 1 1/2. Is this too much?
Thanks, Keith C.
Keith C is offline
Old 08-22-2009, 06:06 PM
Sparky Paul
Sparky Paul's Avatar
With ailerons, if the plane doesn't take off, there's no need for rudders.
One servo for each elevator half, and using a vee-tail mix would work if you need rudders.
I generally install a seperate servo for nose wheel steering on twin boom planes that do take off.
Sparky Paul is offline
Old 08-22-2009, 08:27 PM
Keith C
Thanks sparky,
The plane will not have wheels. Elevator is one piece between booms.
I'll build new one piece rudders.
Happy flying, Keith C.
Keith C is offline
Old 08-22-2009, 09:25 PM
Sparky Paul
On this one, there's a pushrod running across the horizontal from the right rudder to the left rudder.
The servo is up in the front of the right boom.
Old 08-23-2009, 11:10 AM
Keith C
Sparky, That is a lot like what i am building but mine is electric and prop is in front. Booms are peices of "5 gal." paint sticks from Walmart. weight is going to be under 2 # with 46" span.
How about only one working rudder, is this crazy?
Thanks, Keith C.
Keith C is offline
Old 08-23-2009, 06:18 PM
Sparky Paul
Purists might object, but I would no problems with a single working rudder like that.
Old 08-23-2009, 06:27 PM
Bub Steve
Bub Steve's Avatar
Thanks, Keith C.
One will work fine,,I've seen planes with one aileron that flew well, I have two rudder's and nosewheel one,It's easy,, bubsteve
Name:	petty an red 182.jpg
ID:	107844   Click image for larger version
Name:	petty an red 183.jpg
ID:	107845   Click image for larger version
Name:	petty an red 209.jpg
ID:	107846   Click image for larger version
Bub Steve is offline
Old 09-21-2009, 10:35 AM
Keith C
Back to the angle of the elevator/wing question.
I have looked at some ARF's and the wing / tail seem to be on the same plane , however another one has 2-3 deg on the wing with the hor.stab. parallel to the fuse. This is a floater that came underpowered. I am updating power , do i need to change the incidence.
Thanks , Keith C.
Keith C is offline
Old 09-27-2009, 06:21 PM
Sparky Paul
Depends on the wing section. A flat bottomed usually will have a small amount of angle relative to the horizontal, for a floater.
Adding a lot more power will make this angle unsuitable for lots of speed.
Old 09-28-2009, 09:29 AM
Keith C
This one is a low aspect ratio flat bottom wing. I want to keep it a floater but it didn't come with enough power to keep it airborn.
Keith C is offline
mumblinaviator
Foamies
04-16-2009 11:15 PM
diverdon
Foamies
14
07-26-2008 12:05 AM
pstrdenver
3D Flying
04-29-2008 07:59 PM
ElectricMoose
01-12-2008 08:27 PM
xray328
Foamies
07-07-2006 01:22 AM
Quick Reply: horizontal stab angle
Page generated in 0.08496 seconds with 19 queries
