BUSA 1/4 Scale Fokker Dr.1
Old 05-19-2016, 01:58 PM
Mongo40
I'm putting the hinges on the tail an was wondering if there would be a problem using the small hinges on the left, three on each side, or do I need to use the larger ones? Thanks
File Type: jpg
Mongo40 is offline
Old 05-19-2016, 05:00 PM
Either should be fine for elevator.
Rudder on the DR1 can be a problem to hinge. Large surface area and small area for installing hinges.
Use of near scale metal straps with steel wire hinge pin style is recommended.
Old 05-20-2016, 03:05 AM
Mongo40
The rudder on the BUSA Dr1 doesn't use hinges it has a steel rod that connects it through an aluminum tube.
File Type: jpg
Mongo40 is offline
Old 05-20-2016, 04:02 PM
Mongo40
working on covering the wings right now, I've used Sig Koverall an Sig Stixit, then painted several layers of Poly/babypowder mix to fill in the cloth, then sand smooth an primered, so far I've built a working skid, got the fuse covered, sheeted the bottom of the LG Wing, made a battery door on the belly using hinges an magnets to hold it closed.
Trying to figure out how to rig up lower wing skids, may just scratch it an add some carbon fiber skids to protect it, won't weigh as much an won't notice them either, still working on that one.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Mongo40 is offline
Old 05-20-2016, 04:03 PM
Mongo40
Here's the fuse as it stands this morning.
File Type: jpg
File Type: jpg
Mongo40 is offline
Old 05-20-2016, 04:39 PM
Original skids on the wingtips of full scale prototype were actually axe handles, to keep from breaking the wingtips because the aircraft is so top-heavy and the gear is so narrow.
The production skids always looked a lot like axe handles.
Since you probably WILL drag the skids, make them from wood and cut small slots to insert music wire so when it skids, it rubs the wire, not the wood. Done well you can hide the wire with just a bit of the correct color brown paint.
Old 12-17-2018, 04:35 AM
Banditone1
Originally Posted by Mongo40 View Post
Thanks Ron I've watched your video several times before, didn't realize it was electric, what motor do you have in that, love your plane!
Chris
Hello Mongo. Iím new to electrics. Am building a 1/4 Scale Sopwith Triplane. Running a G 110 motor, 9 cells. 20x10 prop. Havenít flown in yet, have taxied though. Handles well. Placing Sound card for motor and gun sounds.
Banditone1 is offline
Old 12-18-2018, 03:27 PM
Banditone1
Default Triplane
Hello Ron
Building a 1/4 Scale Sopwith Triplane. 80Ē ws. Running G110 from Dymondusa. 20x10 e prop. 9000 mah batteries for power. 3000 flt pac. Sound card for motor and gun.
Rich
Old 12-18-2018, 03:29 PM
Banditone1
Default Dr1
Great job on your Dr1
Rich
Old 05-23-2019, 03:38 AM
Mongo40
Hey Banditone, just saw your post, I haven't been on here in quite some time, and still haven't finished the Dr1 it got hung up and some other projects got in the way, hopefully this summer I'll get it finished up, with the receivers having built the in gyros being so previlant now I might even stick one of those in it to help handle it. How's the sopwith tri coming?
Mongo40 is offline
Old 05-24-2019, 05:47 AM
Banditone1
Default Triplane
Hello Mongo
Was just notified that you sent me a message. Doing great on the Trip. Building machine guns for it.2 Vickers and one Lewis Gun. Have sound card to replicate the rotary engine and guns. Also a control card for red LEDís in muzzles of guns. Working on the CG.
Also working with state of Alaska RE:obtain written permission to use there land for a new RC Club a few us are starting here.
Bailout
Old 05-26-2019, 07:16 PM
Mongo40
Might need to make you some skis ro put on the landing gear living up there!
Mongo40 is offline
Old 05-28-2019, 03:49 AM
Banditone1
LOL! Not this time of year, 70 degrees today.
fpveric
05-09-2014 01:16 AM
electriconly
WWI Era
30
09-05-2011 04:43 AM
electriconly
WWI Era
08-03-2011 07:54 PM
scigs30
WWI Era
29
06-08-2011 01:49 PM
scigs30
17
05-09-2011 03:36 PM
Quick Reply: BUSA 1/4 Scale Fokker Dr.1
Page generated in 0.10196 seconds with 28 queries
