Turnigy C2830 for Slow Stick
Old 11-07-2008, 01:25 AM
Bbog100
Bbog100's Avatar
Default Turnigy C2830 for Slow Stick
Is there a stick mount available for the c2830? What is the best way to mount this motor on a slow stick?
Bbog100 is offline
Old 11-07-2008, 01:54 AM
Rolling Thunder
Keep the sunny side up
Rolling Thunder's Avatar
I dont know if you can see this but i mounted mine to a piece of plywood & then mounted it to the stick mount
Rolling Thunder is offline
Old 11-07-2008, 02:03 AM
Bbog100
Bbog100's Avatar
Yep I can see how you have it mounted, thanks. I had ordered 2 of these motors thinking that the towerpro stick mount would work but to my surprise is to small for the motor barrel, live and learn.
Bbog100 is offline
Old 11-07-2008, 04:29 AM
Here you go you can even, epoxy this mount to a piece of plywood, then screw your motor to the plywood, Take care, Chellie
http://www.horizonhobby.com/Products...rodId=EFLM1915
http://www.wattflyer.com/forums/showthread.php?t=39483
Old 11-07-2008, 08:23 PM
Rolling Thunder
I knew I shouldve asked Chellie if there was a mount for one of these,Thanks Chellie -RT
Old 11-07-2008, 10:31 PM
Bbog100
Bbog100's Avatar
Thanks for all the info on the mounts. This is the motor I was talking about, shouldnt be a problem to make one after seeing some options.
Bbog100 is offline
Old 11-07-2008, 10:57 PM
kolchac
RC Lawndart Master
kolchac's Avatar
I have the same motor. I took the guts(motor, gear and shaft) off of a GWS 300 motor and bolted the Turnigy to the front of the empty 300 mount. Workd fine.
Pat
kolchac is offline
Old 11-08-2008, 04:48 AM
LOL Your very Welcome, Anytime, Take care,Chellie
Page generated in 0.10785 seconds with 17 queries
