Current carrying capacity of silicone jacketed wire.
Old 03-15-2012, 12:57 PM
Turbine
Default Current carrying capacity of silicone jacketed wire.
Does anyone have a reliable source of info which sets out the continuous current carrying capacity of the various guages of AWG high strand silicone jacketed wire for electric flight.
Turbine is offline
Old 03-15-2012, 02:17 PM
I think you see wide ranges of numbers quoted due to a large extend because there are different criteria for sizing. If you size the wire based on minimising voltage drop over long lengths then you will end up with quite low amp rating (how low depends on how low a voltage drop you can live with). Alternativly for short wires you might forget voltage drop and size based on how hot the wire will get, keeping it under the max temperature for the insulation type.
Silicone is good for 200C which means you can push more amps through the wire but you do need to decide if you can actually live with your wires being that hot? Also how hot they actually get in prectice depends on if you have any air movement over them, ambient temperature etc.
I found what looks like a pretty good table giving temperatures against wire AWG and amps in still air: http://connectronics.thomasnet.com/A...URRENT--2-.pdf
table attached....
Name:	AWG rating.JPG
Old 04-04-2012, 02:24 PM
Turbine
Thanks for this comprehensive and useful response, and my apologies for the delay in responding.
Turbine is offline
Old 04-04-2012, 07:00 PM
table attached....
That is very good information, Thanks!
Also found info on voltage drop for various sized wires. Just enter in the length of wire in feet (or meters) and the current. This website has a chart that calculates voltage drop for various sized wires that we'd use for a typical model.
http://www.stealth316.com/2-wire-resistance.htm (Ignore the fancy mathematics, and just scroll down to the first red and yellow chart, enter your wire length and current into the data entry points.)
Old 04-04-2012, 10:11 PM
Turbine
Thanks Dennis - another good and useful contribution.
Turbine is offline
06-28-2017 05:22 PM
ceong
Brushless Motor Construction
04-02-2011 04:15 PM
Razmo
Batteries & Chargers
02-04-2011 03:29 AM
Quick Reply: Current carrying capacity of silicone jacketed wire.
Page generated in 0.06650 seconds with 15 queries
