New Product Announcements Vendors post their latest and greatest products here to let the world know about them
AirPower 90mm EDF unit
Old 02-10-2006, 10:37 PM
AIRPOWER
AIRPOWER
AIRPOWER's Avatar
Thumbs up AirPower 90mm EDF unit
AirPower Models manufacture high performance Electric Ducted Fan units using the highest quality material possible. With restrict quality control procedure, AirPower Models products provide high performance that all hobbyist can enjoy!
Designed to produce maximum static thrust in its class. Precision molded fan blade creates high efficiency at all speed. Streamlined cones also smooth air flow thus creates more power and thrust !
COMPATIBLE MOTORS : Mega 22/30, 22/20, Hacker B50, Kontronik...etc
SPECIFICATION:
Outside Diameter: 96.62mm
Rotor Diameter: 90mm, 5 Blades
Weight: 136g (including all parts except motor)
Adapter Shaft: 5mm (CNC Machined 6061 Aluminium)
Static Thrust: 20N (2.0kg)
Max RPM: 45,000rpm
Input Power: 1000W
ID:	7146   Click image for larger version
ID:	7147   Click image for larger version
AIRPOWER is offline
Dirk
Electric Ducted Fan Jets
07-01-2010 05:38 PM
Heiner
09-20-2006 06:39 AM
AIRPOWER
06-05-2006 02:52 AM
Dirk
05-22-2006 07:31 AM
RetroFlight
12
04-04-2006 05:59 AM
Quick Reply: AirPower 90mm EDF unit
Page generated in 0.05684 seconds with 17 queries
