My RoboCat 270 Project DIY - All component need for build one! {Under construction} - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Go Back  WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric Helicopters > Multi-Rotors
Reload this Page >
Multi-Rotors Discuss your quad copters and other multi engined choppers here.
Old 08-10-2016, 03:23 AM
_sOnGoKu_
_sOnGoKu_'s Avatar
Thumbs up My RoboCat 270 Project DIY - All component need for build one! {Under construction}
Hi wattflyer friends, I'd like to share my experience in the construction of my first racing drone.
I've never assembled one before, (so everything is a surprise for me) to get started in the world
of drones and after make some search, in my opinion this kit is a perfect base for it.
In this thread i will adding the 3D printable improvements that go specifically designed for this model all ready Done:
3d Power PCB Support model
Future improvements:
Led light for Tail / Nose, Camera Supports ,GPS Supports, Battery holder
This RoboCat 270 kit has been courtesy of Gearbest guys, one serious and very big website were
you can both for setting up your DIY drone or to get yours already assembled from factory and soo on.
Thank you all you guys!! you are Awesome!!
Back to the drone , this thread includes actually all you need for assemble your Drone.
here you can see the components i use in this project and all the tech spec:
Carbon fiber Quadcopter Frame
Marspower 2204 Motors x4
Propeller 5030 x4
CC3D flight controller
power distribution board
Lipo LiFe Low Voltage Buzzer Alarm
12A motor ESC
Battery 2200mAh 11.1V 30C Lipo
Transmitter
Charger compatible
kit with some parts
Here is the Store where i buy it.
This RoboCat feels very balanced from beginning, against other equivalent others, this has very good reputation for its
fine stability of flight and response. Easy to drive and assemble in a simple beautiful line. For all that reasons it has been selected to start this project.
Also is fully upgradeable one of the things because i love it.
This means little by little you will be able to add more things to your drone, to leave it as you like...
GPS, FPV, 3D Print improvements, etc..
Carbon fiber chassis feels rugged, lightweight. It has a thickness of 1.5mm thick fuselage and 3mm thick arms for better support
the power from motors .
In the videos you can see a fast assemble and all parts received in a single pass.
Hardware is very easy to identify it comes with not instructions, but however leave an image that came to me very well for the Assembly of the Robo.
Patience at the time to assembly It is also recommended, above all if it is the first time that you mount something,
you do it somewhere quiet, with enough space to see all parts and work in a comfortable area.
I had never build one before and it took about 30 hours (counting tests and other surprises along the way).
I don't think that required any technical special knowledge to come out all right, perhaps more complicated for some of the mounted,
may be it welds with Tin (but is very easy with a little of practice)
Here you can see clearly as they have to go the engine welded to the ESC,
so two rotate in clockwise direction and the other two to the contrary.
These engines can get to spin very fast, certainly for this drone are more than enough. A touch of throttle and shoots out the drone.
The advantage of these motors and brushless is that friction is minimal. Which translates into better performance and less maintenance.
I've see that many of the people who assemble this kit say that power PCB, does not work for this model.
This is not entirely correct, I've been able to fit it perfectly, including the two frames carbon fiber which includes the chassis.
The trick is cut to size. This Power PBC is also made as an octocopter, (but we are not going to use those connections) Then the best way to go is cut.
To secure the power PCBto the chassis, I designed a piece that fits perfectly with this board model and fixed with screws to the chassis of the RoboCat.
On the next floor of the drone, we have the battery compartment, I've chosen one of 30C / 3S, giving power for 10 or 12 minutes of flight.
In future 3D improvements shure i make some support for quick battery replacement.
The only problem that I found when installing the control flight CC3D, is that I was able to integrate the anti-vibration support that comes in the Kit.
A layer above, we have the CC3D, has captivated me, super simple to set up, has been to connect it by usb to the ground station,
and in less than 10 minutes to have everything set up and ready to fly.
Think it is advisable to protect from vibration everything we can this Board, but I have been unable.
At the end what I did was stick it to the middle frame, as shown in the videos:
The software of this flight controller is based on "librepilot" open source so it is perfect to configure it as you need.
Depending on your level of rider, you can start softer and not broke your drone while learning to fly.
once you already take more esperience is going to be easy to modify the parameters of your Robocat and load more aggressive flight configs on your CC3D board.
For more information about Librepilot see this link
Connected to the CC3D I have the receiver and Transmitter Sky Fly FS T6, with a simple wiring per channel and protected by the external housing feline line from this model.
On the right side, I had to drill a little the side plastic protection, since it could not connect the ESC drivers.
In my conclusion, this drone i believe that it can make dreams reality of anyone interested in started in the world of the drains with a serious model and quality.
Not be mistaken when I say is also a drone for starters, this dorne has a RACING spirit in all parts of his body and configured in an aggressive flight mode,
it can be very very fast..
I have learned to fly dornes with it , i steel no too much good, but 100% recommend for start, is easy to Fly and config.
I can help with the basic configuration from the Transmitter and the CC3D flightboard.
Message me if you have trubles.
Thanks for watching!
File Type: jpg
_sOnGoKu_ is offline
Old 08-11-2016, 02:16 AM
_sOnGoKu_
_sOnGoKu_'s Avatar
some videos more i have made
Here you can se first flight out video
Here a Timelap from the construction
Old 10-01-2016, 06:13 PM
_sOnGoKu_
_sOnGoKu_'s Avatar
i have recived some new Propellers for use they with my Robocat 270, 3 diferent types, 3-blace Nylon , normal Colored ABS and carbon fiber one
Old 10-02-2016, 01:59 PM
OUTSTANDING SHARING!!!!!!!Absolutly love seeing another multi rotor thread,and a build thread at that.
GoKU,looks like your doing a great job. Now to watch your vid's
Old 10-02-2016, 02:07 PM
_sOnGoKu_
_sOnGoKu_'s Avatar
Thank you very much tobydogs, I'm glad to hear that anyone is interested the thread
now I'll have a few days off take the opportunity to change a little bit the settings and up 1 "click" the settings
but I still a bit of a novice, so better to go little by little..
I send you regards friend and thanks for look my vids
Old 10-02-2016, 02:50 PM
Just finished the time lapse vid and a few other that pop up. Wish building could be that fast sometimes. Like when we need to do repairs.
Ya gotta get FPV!!! That way we can see some speed flights. 20 or 30amp esc's and a 4cell pack would be also a great upgrade.
I almost forgot....Welcome to Wattflyer my friend!
Heres a few pictures of my fpv hanger just to show how much intreest i am having with multiroros.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old 10-02-2016, 03:00 PM
_sOnGoKu_
_sOnGoKu_'s Avatar
Woow friend i see! is a tremendous honor to have you posting in my thread. These machines are very very pro style.
I am a complete newbie ,is just a few months I've fly my first drone ever. Just tell you I've never tried FPV ,, imagine..
Although I have very clear that is the next thing you'll do .. I really want to feel that experience , and im pretty sure i will love it.
were i can see you vids? pass me you youtube channel , i will like to have a look
regards,, Ha! and thanks for the welcome
Old 10-02-2016, 03:17 PM
Heres a few, to many and so many boring ones.
https://www.youtube.com/watch?v=9sYRfZfbuSQ
https://www.youtube.com/watch?v=D6xt...?v=5ljh27qrbXE
https://www.youtube.com/watch?v=R8dnqA1Rn_0
Old 10-02-2016, 03:19 PM
_sOnGoKu_
_sOnGoKu_'s Avatar
Thanks cool! i will have a look
Page generated in 0.09894 seconds with 20 queries
