3" disc only instructions - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 01-20-2016, 01:58 AM
Texasmark
Default 3" disc only instructions
Second posting, newbie to RC.
Seems I ordered and received 2 rx/tx systems. This second one is a Fly Sky brand and instructions are on a 3" disc.
My imac won't accept abnormal diameter discs.
What to do, what to do. More buy buy buy.
Thanks for any responses.
Mark
Texasmark is offline
Old 01-20-2016, 02:10 AM
The normal response to any question about making a Mac work is....
Buy a real computer
The CD/DVD tray SHOULD have a smaller , deeper indent for centering the smaller CD. Apple and Win/Intel machines use the same CD/DVD drives.
Then the question becomes whether the computer can actually read the disc format.
Old 01-20-2016, 02:45 AM
Wrongway-Feldman
Wrongway-Feldman's Avatar
The nice thing these days is that most if not all documentation is available online.
Google the model of your radio and you'll find it quite readily.
Wrongway-Feldman is offline
Old 01-20-2016, 02:46 AM
Look for a PDF on the mfg. website.
Old 01-20-2016, 07:28 AM
hayofstacks
hayofstacks's Avatar
Slot type disc loaders will not load the micro discs. You need an actual tray style to use them. Had that problem way back when. My uncle used to make CD business cards to fit in a wallet.
hayofstacks is offline
Old 01-20-2016, 08:20 AM
Mark
Go to FlySky website - all manuals are there to download.
Old 01-20-2016, 01:44 PM
Texasmark
Buy a real computer
Sorry sir but I HAVE a real computer! No tray with a mac. I know what you are talking about but that would be an external accessory....my Dell and Toshiba laptop (running Windows...ugh.....) don't have that either.
My Mac has a slot on the side of the monitor.....since everything but the keyboard and mouse are in the monitor. To insert a normal sized disc, it goes in about half way before the drive picks it up and sucks it into the machine. On a 3" I can't get there without turning loose of it and when I got to that point, I felt that I needed a remote disc scanner.......before I lost it inside and had a dismantling job on my hands.....in retrospect, a wise decision.
Thanks,
Mark
Old 01-20-2016, 01:49 PM
Texasmark
Today I jumped out of bed at 5 AM and got a lot accomplished with regard to that. I have the manual downloaded and read where I didn't need to do/buy a lot of stuff and do a lot of computer work I initially thought I'd have to.
Lot better manual than the one with my Spektrum SPM1000.
Thanks for the reply,
Mark
Old 01-20-2016, 01:52 PM
Texasmark
I have since come to that conclusion, but as luck would have it, the good old www comes to the rescue again. Found out that the disc only contained the manual(s) and I got it/them downloaded already from the www. So I didn't need to buy that nor a downloading cable to plug into the Tx. Today is going to be a good day.
Thanks,
Mark
Old 01-20-2016, 01:53 PM
Texasmark
Thanks. I found that out this AM.
Mark
Old 01-20-2016, 01:54 PM
Texasmark
Found it. Thanks,
Mark
Old 01-20-2016, 05:00 PM
Wisc-BK
Watch this........:-(
Wisc-BK's Avatar
I know this is a little late, but another good solution is to go to your local library and ask them to copy the disk to a larger format disk ( that you would bring with you ). Most all libraries have laptops that you can either check out or use right there in the library and copy the disk your self. Most libraries run non-apple computers since they tend to use the same software nationwide mange their operations.
A lot of libraries have restrictions built into their management system to stop customers from doing copying and storing stuff on their hard drives, but if you ask at the counter I'm sure they will help you out with machines they have behind the counter.
This from a person married to a retired library worker.
Wisc-BK is offline
Old 01-20-2016, 05:22 PM
http://www.amazon.com/Digital-Innova.../dp/B0001654X6
Old 01-21-2016, 02:30 PM
Texasmark
Thank you sir.
Old 01-21-2016, 05:17 PM
Buy a real computer.
LOL
I have a "real" Windows desktop PC. It will not recognise those little CD's. Had to use my wife's Dell PC to save the files to a USB drive.
Old 01-21-2016, 05:53 PM
LOL
it not the Computer ... its the tray or lack of to the CD Drive that is usually at fault. Of course the FAT system may not be suitable for certain PC's ....
Old 01-21-2016, 08:02 PM
My PC is a HP Pavilion, about two years old. The DVD tray does have the proper indentation for the little CD's. Didn't work. My wifes PC is an All-In-One unit where the DVD drive is vertical. Worked just fine.
Really odd.
gduk
Vintage and old timer models
06-15-2014 03:55 PM
Joe 1320
Electric Ducted Fan Jets
07-31-2012 10:54 AM
Maxxadict
Warbird Electrics
01-21-2012 08:05 PM
molokaiboy
07-28-2011 08:51 AM
Quick Reply: 3" disc only instructions
Page generated in 0.11557 seconds with 9 queries
