Build report: Hobby-Lobby F-16 Pusher Jet - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 05-19-2008, 04:17 AM
michael7810
Default Build report: Hobby-Lobby F-16 Pusher Jet
I picked this up at the crash sale a couple weeks ago and finished the build this weekend. Flying weather is almost over in </O:p
I had planned to build it with two servos (1 for each elevator) and either rig the ailerons to work with the elevators OR rig the elevators as elevons. I though I could just add the aileron servo later if it didnít fly right. That was the plan; but the first step is to install the aileron servo because the forward and aft fuselage pieces and both wings bury the servo. Plan B; I traced all the foam parts on cardboard so I could build another jet later after seeing how it flies build per the plans.
<O</O
The only issue with the parts was aileron push rods were too short which required about a 1.5-inch extension.
<O</O
This is my first foamie build so I experimented with gorilla glue, FSCA, and epoxy. I tried mixing the GG with water (I read that somewhere) which was a mistake for this application. That has got to be the stickiest stuff on earth. I found 20-minute epoxy for the parts I could let set overnight and 5-minute epoxy for the parts I had to hold together worked best. I used FSCA to fasten the elevator servos. Next time I will skip the GGÖlessons learned.
<O</O
The rest of the build was easy following the instructions. The only piece of data the instructions lacked was control surface throws. It ended up with 3/8-in on the elevators and 5/8-in for the ailerons. AUW is 13.25 oz. The crash sale included a LittleScreamer Park Jet motor (MMC2800) that advertises to pull 180 watts. That would fly my 48-inch Super Sportster!! I installed a 6x4 prop and at full power with a 3S Lipo it pulls 17 Amps. Just short of the 18 amp max according to the instructions. The area around the motor buzzes pretty loud (more like barks like a dog) above 12 amps. Iím not sure how will be in flight. Iíll beef up the elevator area with carbon rods on my next build (or first rebuild). <O</O
<O </O
Iíve included some pictures of the completed project. I used a 3S1P2100 Lipo close to the nose to get the CG at the recommended 8 cm back from the leading edge. <O</O
<O </O
Iíve never flown anything like this so any tips from the readers will be appreciated. I have a fair amount of time with trainer and sport models but Iím a little nervous with this one.
michael7810 is offline
Old 06-01-2008, 03:54 PM
oct2633
Smile Good Build
I had planned to build it with two servos (1 for each elevator) and either rig the ailerons to work with the elevators OR rig the elevators as elevons. I though I could just add the aileron servo later if it didn’t fly right. That was the plan; but the first step is to install the aileron servo because the forward and aft fuselage pieces and both wings bury the servo. Plan B; I traced all the foam parts on cardboard so I could build another jet later after seeing how it flies build per the plans.
<O</O
<O</O
This is my first foamie build so I experimented with gorilla glue, FSCA, and epoxy. I tried mixing the GG with water (I read that somewhere) which was a mistake for this application. That has got to be the stickiest stuff on earth. I found 20-minute epoxy for the parts I could let set overnight and 5-minute epoxy for the parts I had to hold together worked best. I used FSCA to fasten the elevator servos. Next time I will skip the GG…lessons learned.
<O</O
The rest of the build was easy following the instructions. The only piece of data the instructions lacked was control surface throws. It ended up with 3/8-in on the elevators and 5/8-in for the ailerons. AUW is 13.25 oz. The crash sale included a LittleScreamer Park Jet motor (MMC2800) that advertises to pull 180 watts. That would fly my 48-inch Super Sportster!! I installed a 6x4 prop and at full power with a 3S Lipo it pulls 17 Amps. Just short of the 18 amp max according to the instructions. The area around the motor buzzes pretty loud (more like barks like a dog) above 12 amps. I’m not sure how will be in flight. I’ll beef up the elevator area with carbon rods on my next build (or first rebuild). <O</O
<O </O
I’ve included some pictures of the completed project. I used a 3S1P2100 Lipo close to the nose to get the CG at the recommended 8 cm back from the leading edge. <O</O
<O </O
I’ve never flown anything like this so any tips from the readers will be appreciated. I have a fair amount of time with trainer and sport models but I’m a little nervous with this one.
Attachment 66454
Attachment 66455
Attachment 66456
Attachment 66457
Attachment 66458
Attachment 66459
Attachment 66460
Attachment 66461
Attachment 66462
Looks to me like an excellent build job Michael. Should fly well. Did you try low temp hot melt? Give us a flight report!
oct2633 is offline
Electric Ducted Fan Jets
75
09-04-2018 01:35 PM
Foamies
233
01-06-2016 10:40 PM
markind
74
06-14-2009 08:17 PM
michael7810
06-01-2008 05:53 PM
Crash Test Dummy
Foamies
25
10-05-2005 05:18 AM
Quick Reply: Build report: Hobby-Lobby F-16 Pusher Jet
Page generated in 0.05015 seconds with 14 queries
