Seaplanes E-Powered Discuss electric powered seaplanes here
Guan Li repowered.
Old 03-03-2011, 10:30 PM
cyclops2
Default Guan Li repowered.
On a .....motor prop calculator.... this setup looks good. 24 oz. RTF.
Each motor is 12 vdc..6 amp.. GWS RS 9 x 7 x 3 ..11.7 to 1
About 6 minutes at a continous WOT. Static thrust 19 oz. 38 mph.
I am using 4 Black & Decker A123...1100 mahr... cells.
I was sitting pretty low in the water with the stock motor/gearboxes & the B & D cells.
What are some of your weights RTF with similar mahr. lipos ?
Name:	Hyperion 12 mm & GWS 9 x 7 x 3 blades.jpg
ID:	144227   Click image for larger version
Name:	Repowered Guan Li for lighter weight. 001.jpg
ID:	144229   Click image for larger version
Name:	Repowered Guan Li for lighter weight. 002.jpg
cyclops2 is offline
Old 03-05-2011, 07:07 PM
cyclops2
Default Good news & bad news.
The plane wing is finished. Needs spackle drying & sanding.
Had to pull both stock servos. Too noisey. Lighter H-55s are in.
4 ...Black & Decker A123 cells of 1100mahr just makes the COG perfect when pushed against the front piece of the cocpit tray
Bad news is I DO weigh 27 oz. with the LIFEPO4 cells. 6 oz of dead weight.
I will straighten the antenna wire & run it from the back of the wing to the top of the vertical stabilizer. I have a 12" long 1/8" drill bit to drill a hole straight down to hide the last 7" of the antenna.
I am REALLY dinging the daylights out of the foam edges. More spackle...
Anybody getting Feigao 6 amp ESCs from somewhere ?
Name:	Final rewire of the Hyperion 12 mm 5980 kv motors & spackle. 001.jpg
ID:	144309   Click image for larger version
Name:	Final rewire of the Hyperion 12 mm 5980 kv motors & spackle. 002.jpg
cyclops2 is offline
Old 03-07-2011, 09:10 PM
Lancer31
Lancer31's Avatar
Default What are we talking about?
Guan'Li makes several models, Cyclops2. I can't tell from your posts which model it is.
Attached is a picture of my Guan'Li seaplane, an Icon A5.
Lancer31 is offline
Old 03-07-2011, 10:06 PM
cyclops2
Hi Lancer.
I am taking the 73 amendment. My age.
I am redoing my first PBY. It really was a bad QC job. All sealed up now.
That is a sharp looking plane !!
I really need to go to a site that has all of their planes to look at with the specs. also. I have all the GWS planes I want. I like props.
The motors are Hyperions 12 mm diameter 5980 KV on +12 vdc.
I am trying to find out if any of my ESCs can drive the tiny motor to 60,000 rpm. motor, gearbox & the 9 x 7 x 3 blade weigh .9 oz.
cyclops2 is offline
Old 03-07-2011, 10:07 PM
cyclops2
Default Just noticed.
It is a modern looking Seabee ! Neat.
cyclops2 is offline
Page generated in 0.09846 seconds with 19 queries
